Hi everyone!
I've bought this DSO and I've discovered a problem on channel 2.
With ch1, ch2 and ch3 connected on 2Vpp/1kHz square wave I get on ch2 an offset [5V/div].
If I decrease volt/div I no longer see the waveform on ch2. It goes off screen at the top.
I have already swapped several components in this order between channel 2 and 3 but the problem remained on channel 2[see SwitchedParts.png].
- 1. 6552
- 2. ad8510
- 3. ad8370
- 4. 3 MMBTH10 marked 3em
- 5. PMBF4393 marked w6g
I have access to the serial interface but I don't know what to check.
Then I've found a difference in Offset_details.png area.
Here I get:
ch1 -2,379v
ch2 -2,328v
ch3 -2,373v
ch4 -2,362v
Going backwards from this area I arrived at a Hex inverter (?!?) And touching the L1302 inductor with the multimeter in Volt mode, the waveform goes up (offset upwards).
any idea how to fix?
