Author Topic: Dual 30V/5A lab supply MCP M10-DP-305E equivalent  (Read 3429 times)
Offline shakalnokturnTopic starter
« on: February 22, 2020, 01:41:51 pm »
I have one of these cheap-built but good by today's standards linear lab supplies.
One output has no regulation can anyone identify clones-of or similar models that I may be able to find a schematic for?
The regulation PCB's are marked "DCPOWRE-1C". (Engineer was dyslexic...)
Thanks!
Re: Dual 30V/5A lab supply MCP M10-DP-305E equivalent
« Reply #2 on: February 22, 2020, 04:34:56 pm »
Thanks, the HY3005D definitely seems close at a first glance. I'll took into that in more detail later.
« Reply #3 on: February 25, 2020, 10:29:12 am »
Thanks to Grandchuck for pointing me towards my PS being a not so fantastic Mastech clone.
I found a few crusted and rusted relay switching transistors, the current regulation problem was a defective UA741.
Moderators: Feel free to move from T.E. to repair if more appropriate.
« Reply #4 on: February 25, 2020, 11:14:01 am »
You can Move Topic yourself.
Look bottom left of your page for the link.
The following users thanked this post: shakalnokturn
Offline SkyMaster
« Reply #5 on: February 26, 2020, 04:38:33 am »
The MCP M10-DP-305E and Mastech HY3005F-3 were probably heavily "inspired" by the GW Instek GPS-2303.
Offline issa
  • Country: jo
« Reply #6 on: March 15, 2020, 10:53:49 pm »
Hello there,
I am new here so please pardon my mistakes, i have the same exact device , can you lease help me find out the values of a few brunet resistors?
either schematics or close ups? please?
the resistors are brunet beyond recognition.
R1, R2, R3, R5 ,R6, on the front control board named MCP-36A
The large green resistors on the back plate.
If there is a schematic i appreciate it.
Last, the main power transistors on the back are expensive and hard to find , is there a viable replacement?
Thank you all in advance,
« Reply #7 on: March 17, 2020, 08:40:14 am »
One of the schematics (the one with 3 relays and three TO-3 transistors) for the Mastech models has the right values for the power resistors at the rear.
I don't think any of the schematics I saw showed an identical (with optocouplers) control PCB though.
I'll see if I can help for those values.
« Reply #8 on: March 17, 2020, 08:39:35 pm »
Front adjustment PCB:
R1: 1k
R2: 470R
R3: 1k
R5: 470R
R6: 1k
Edit: I won't be trying to help newcomers much longer, I'm under the impression that they mostly loose track of their own requests.
« Last Edit: March 18, 2020, 08:19:18 pm by shakalnokturn »
Offline cripto25
« Reply #9 on: April 16, 2020, 05:37:33 pm »
Hi. Although I am new here, I have been browsing this forum for some time and I have always learned something. on this topic I want to make my contribution.
I have an MCP M10-TP-305E source that stops working when testing a universal brush motor.
I attach photos with the components that I needed to change until I can get it to work again.
Thanks to shakalnokturn for the contribution of the value of the resistances since I do not have the scheme.
971270-0
Offline issa
  • Country: jo
« Reply #10 on: October 30, 2024, 02:43:53 pm »
Thank you, i know its a late reply. but i never did thank you.
so thank you.
 the right side is not working at all. i cannot figuer out why.
i am still lookiong for schematices
Offline Harry_22
« Reply #11 on: October 30, 2024, 03:42:15 pm »
Hi!
What about the right side?
Could you picture front panel with measurements like at first post.
