Author Topic: Dual Apodys Chloride Ups Inverter Can Bus Communication Problem:: Urgent !!!!  (Read 634 times)
Offline DURBUGTITopic starter
  • Country: pk
Can anyone has any idea as to What Timeout means in reference to Dual Parallel APODYS 18 KVA Emerson Chloride UPS.
We have an alarm for" CAN Communication Problem" INVERTER TIMEOUT AND ? MARK ON DISPLAY when AC Supply breaker is energized, though the Charger is normal i.e there is no alarm.
Red Led Flashing on display
Note : Its partner UPS is healthy but in shutdown position
Urgent Response is awaited.
« Last Edit: July 07, 2024, 06:30:43 am by DURBUGTI »
Offline coromonadalix
please  do not write in capital letters  it is considered yelling, you may not be appreciated
see an answer and a file  i posted on your other thread, it may help
if not, try to contact the company
Offline krishn61
  • Country: in
Hi, I am also facing the same problem. Can you share the possible solution if you have
