I typically use Simple Green or Oil Eater, scrub with a brush, rinse off in the sink, and then depending what it is sometimes a wash with isopropyl alcohol and then let it dry thoroughly. If your tap water has a lot of minerals then it's better to use distilled water but the water out here is fine.
