Hello, if you're still around, the problem with the TV is the diffuser...there are four strips, two on the left edge, and two on the right edge...somehow, the hard diffusing light pipe sheet, that the strips shine into the edge of, has deteriorated or distorted...I worked on one of these, same model, and there's nothing burned, darkened, or otherwise visibly bad about the diffuser, it's just no longer transmitting the light all the way through. I spent several hours replacing all four strips, even though the old ones still looked and shined bright like new. Sony junk, I guess.
