Author Topic: Chauvin Arnoux E3N  (Read 3645 times)
Offline mendip_discoveryTopic starter
Chauvin Arnoux E3N
« on: February 01, 2024, 07:10:58 pm »
So I have a Chauvin Arnoux E3N but it's got a broken coax at the end of the strain relief.
Annoyingly I can see a screw that would allow me to get to the end of the cable where I might be able to repair the wire but I cant get to it becuase the handle is in the way.
So anyone got any tips on how to take this thing apart?
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline Greybeard
Re: Chauvin Arnoux E3N
« Reply #1 on: February 02, 2024, 04:02:25 pm »
Pictures, please...
« Reply #2 on: February 02, 2024, 06:28:11 pm »
So I had a go this evening at taking it apart. They really don't want you fixing these things.
Managed to get the covers off the side, they lift up a little then rotate and ping off. On one side you can see a screw for a pot to adjust it.
I manged to lever the case enough to get one side over the peg but the other side wouldn't go and I didn't want to break it. Might give it another go in a moment.
« Reply #3 on: February 02, 2024, 06:29:22 pm »
Some pics fell off the last post.
« Reply #4 on: February 02, 2024, 06:46:22 pm »
So I hit it with a hammer...
« Last Edit: February 02, 2024, 06:48:10 pm by mendip_discovery »
« Reply #5 on: February 02, 2024, 07:02:23 pm »
and I am in,
Turns out the core wire of the coax has broken.
Offline Greybeard
« Reply #6 on: February 02, 2024, 07:04:14 pm »
There are very similar Agilent, Fluke and Instek current clamps:
« Last Edit: February 02, 2024, 07:38:14 pm by Greybeard »
The following users thanked this post: shakalnokturn
Offline shakalnokturn
« Reply #7 on: February 03, 2024, 12:43:55 pm »
Going by the internal photos I believe Chauvin Arnoux are the OEM.
Je ne dis pas ça par Chauvinisme  ;D
Offline Greybeard
« Reply #8 on: February 03, 2024, 10:49:05 pm »
You're probably correct.
I found this post here in the forum:
If you want a good general purpose DC current probe, look at the:
Tektronix A622, it is 100A but only 100 kHz
It is made by AEMC, Model SL261
and also sold as Fluke, 80I-110S
or Agilent 1146A
https://www.eevblog.com/forum/testgear/suggestions-for-dc-current-probes/msg1001757/#msg1001757
The service manual including schematics of the AEMC Model SL261 can be found here:
https://www.manualslib.com/manual/1561143/Aemc-Sl261.html?page=2#manual
Last page of the service manual:
MODEL SL261
Repair and Calibration
To ensure that your instrument meets factory specifications, we recommend that it be submitted to our
factory Service Center at one-year intervals for recalibration, or as required by other standards or
internal procedures.
For Instrument Repair and Calibration:
You must contact our Service Center for a Customer Service Authorization number (CSA#). This will
ensure that when your instrument arrives, it will be tracked and processed promptly. Please write the
CSA# on the outside of the shipping container. If the instrument is returned for calibration, we need to
know if you want a standard calibration, or a calibration traceable to N.I.S.T. (includes calibration
certificate plus recorded calibration data).
Chauvin Arnoux ® Inc.
d.b.a. AEMC ® Instruments
15 Faraday Drive
Dover, NH 03820 USA
Tel:  (800) 945-2362 (Ext. 360)
       (603) 749-6434 (Ext. 360)
Fax: (603) 742-2346 or (603) 749-6309
repair@aemc.com
« Last Edit: February 04, 2024, 12:35:00 am by Greybeard »
