Author Topic: E.S.I 2150 Video Bridge power supply question.  (Read 595 times)
Offline PaceguyTopic starter
« on: June 30, 2023, 02:44:33 pm »
Hi, Does anyone familiar with the E.S.I 2150/2160 series Video Bridge know if I can use a 2A 600 volt bridge rectifier on the power supply board in the place of the 1.5A 800 volt bridge called for on the parts list? The mains fuse is 2 amp slo blo, but the bridge is rated for 1.5 amps and shorted out. Thanks in advance for any advice!
Online wasedadoc
Re: E.S.I 2150 Video Bridge power supply question.
« Reply #1 on: June 30, 2023, 04:10:56 pm »
I don't know this equipment.  Is the bridge rectifier on the input AC mains of a SMPS rated for 90-250 Volts input?  If yes  and it will only be connected to 110 Volt AC mains then yes a 600 Volt bridge rectifier will be OK.
But before fitting it you should be seeking the answer to the question of why is the existing one shot?
« Last Edit: June 30, 2023, 04:13:06 pm by wasedadoc »
« Reply #2 on: June 30, 2023, 04:45:41 pm »
There were a couple of parts that had failed, a shorted horz. output transistor and a stud diode was open too. I have replaced both. The power supply is not a SMPS, it's the conventional type with two large size electro caps that are rated at 200v.
« Last Edit: June 30, 2023, 04:49:11 pm by Paceguy »
Offline m k
« Reply #3 on: July 05, 2023, 02:43:25 pm »
There's a 230V setting so it needs more than 600VAC.
But secondary faults shouldn't cook the rectifier.
Maybe it was just too old.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Online wasedadoc
« Reply #4 on: July 06, 2023, 11:03:30 am »
The schematic for the relevant part of the power input is at the top of page 246 of the pdf which can be downloaded at https://www.manualslib.com/download/2086388/Esi-Videobridge-2150.html.  The 110/230 Volt switch has no impact on what is applied to the bridge rectifier.  As I wrote above, if used only on 110 Volt input (the OP is in Canada) a 600 Volt bridge will be OK.  Fitting an 800 Volt bridge would be preferable but if that is not available a label should be applied stating that the unit should not be used on 230 Volt mains.
The following users thanked this post: m k
« Reply #5 on: July 06, 2023, 05:14:20 pm »
I have ordered some 2 amp 1000V, type 2W10 bridge rectifiers. I should be getting them soon and will get back to this post with the results. Thanks to those who have taken the time to give advice so far.
