I have some E3604A.
When I set the voltage using the limit button say to 6V. then I enable the output and it sort of goes to 5.998V on the display, might drift down to 5.997V
Fluke says that is what the output actually is 5.997V.
Is this damaged, or calibraiton issue?
I tried a simple calibration using my meter and I don't think things really changed at all. (That said I didn't use the current sense 0.1ohm as recommended in the service manual, use the I of the meter). That said if you are out at all it won't accept your calibration either so was probably not bad meter measurements.
Anyone own this and can confirm this behaviour is due to calibration or due to some other issue?
