I just picked up a E3631a. I read this repair (
https://www.eevblog.com/forum/repair/agilent-e3631a-problems-i-just-keep-getting-lucky-not/msg3610050) but my situation seems different.
At power on: +6V reads 0.201V 0.036A CV
I can set a limit voltage, say 4V. I can set a limit current.
If I connect a voltmeter without adjusting the output voltage, the voltmeter displays the limit voltage (4V).
If I reduce the output level (not in limit mode) the display does not change, still shows 0.201V but the connected voltmeter shows the lowering value.
If I increase the output level (not in limit mode) the display does not change, still shows 0.201V but the connected voltmeter shows the increasing value.
In addition, I can adjust the output so it exceeds the previously set limit value. The display still shows 0.201V but the connected voltmeter displays the increased voltage (above limit) AND if I switch back to limit mode, the limit value is now HIGHER than what I previously set and it matches the voltmeter.
Anyone have any suggestions on where to start debugging?
