Author Topic: e3642a power supply problem  (Read 628 times)
Offline idaTopic starter
« on: December 08, 2021, 12:51:36 pm »
Use 34411a to detect the 5v power supply output by e3642a, and find that the waveform is a bit jittery, and there is a little regularity (about once in 70 seconds), and the jitter amplitude is between 600uV.
Is the e3642a power supply faulty?
« Last Edit: December 08, 2021, 03:24:43 pm by ida »
Offline ESTechnical
    • ESTechnical - Reflow ovens and controllers
Re: e3642a power supply problem
« Reply #1 on: December 08, 2021, 01:00:41 pm »
Can you make a current draw measurement and see if these are correlated?
« Reply #2 on: December 08, 2021, 02:57:01 pm »
Measure the current, 5V R1K 5MA. If it is a power failure, which part may be caused by it?
« Last Edit: December 08, 2021, 03:24:12 pm by ida »
