Author Topic: Agilent E4421B RF generator restoration project  (Read 25069 times)
Online nctnicoTopic starter
Re: Agilent E4421B RF generator restoration project
« Reply #25 on: January 27, 2019, 11:13:18 pm »
My E4421B has thrown me a nasty curve ball today. It starts but when it gets to the splash screen I hear a loud click from one of the RF modules and it seems to reset into the splash screen. This cycle keeps continuing  :-BROKE Just as I wanted to make some measurements on my new HF differential probes.  :rant:  :rant: Just what I need. Maybe it is karma. A few days ago I have bought a different RF generator which hasn't arrived yet. Hopefully that is in a somewhat workable condition.
« Last Edit: January 27, 2019, 11:46:18 pm by nctnico »
Offline Samogon
« Reply #26 on: January 28, 2019, 12:38:00 am »
Looks 5V power rail has an issue, fail at load, making reboot cycle. That is first thing i would check.
Then if 5V ok, remove all boards except digital and check it
« Reply #27 on: January 28, 2019, 01:00:39 am »
The 5V looks ok with a DMM. I also see the diagnostic LEDs keep counting in a binary sequence. With all the RF modules removed the behaviour is the same. Maybe I need to try and reflow the SRAMs. There is a message about the RAM but it isn't clear if something is bad or not. It says:
Start = 0x300000
End =  0x3F9800
Errors =0x0
With the 'local' button pressed during power on, the E4421B won't start the firmware so the self test result stays on screen.
« Reply #28 on: January 29, 2019, 09:34:02 pm »
I made some progress. When it is cold and no RF modules are installed it will start succesfully. I tried using freeze spray but so far no joy.
Offline Samogon
« Reply #29 on: January 29, 2019, 09:56:35 pm »
Thermal camera?
Measure cold and warm current consumption on 5V rail
« Reply #30 on: January 29, 2019, 10:16:48 pm »
I'm not so sure this is 5V related. I'd expect the system to do a full reset (go through the bootloader) when the power fails. Instead it seems the application crashes and restarts itself. Yes, I already re-seated all memory chips in sockets on the main board.
The chassis allows for a whole bunch of extra boards (which aren't in my machine) so my assumption is that the power supply has way more power than necessary. I won't rule the PSU out but using freeze spray on it hasn't solved the issue. It also doesn't smell like cat-wee which is a tell-tale sign of a bad electrolytic.
« Last Edit: January 29, 2019, 10:19:35 pm by nctnico »
Online TK
« Reply #31 on: January 29, 2019, 11:37:24 pm »
There is a LED array indicating the status of the different power rails.  If all of them are ON, then the power supply is OK.  During boot, there is another LED array that indicates the boot step and once all tests pass, it counts up-down.  If it stops with a specific patter, then you can read the hex value and look at the service guide.
« Reply #32 on: January 30, 2019, 06:02:53 pm »
All the power leds are on and the status LEDs don't stop at a specific pattern. The bootloader and self tests are OK. It is the application itself which crashes. The status LEDs invert after the bootloader is finished and the left 4 (with the display towards you) are showing a binary counting pattern. When it starts OK then all the status LEDs are showing a counting pattern.
« Reply #33 on: January 31, 2019, 10:15:35 pm »
I found a rather large ripple on the 12V supply (200mVpp). The capacitors in the PSU still measured OK though and replacing them didn't help. I'm going to sell the generator 'for parts'. With all the repairs I did on it and the hacked output amplifier it is not going to be worth much even if it works. I have a 'new' RF generator coming my way anyway.
Offline Samogon
« Reply #34 on: February 01, 2019, 02:25:53 am »
This is not outcome we all expect
The following users thanked this post: minsik
Offline pquadrat
« Reply #35 on: February 08, 2019, 07:15:09 pm »
This thread is old but I think it is worth keeping any repair hints together.
Recently I acquired this signal generator and had missing columns on the bottom half of the LCD.  After replacing the LCD, the problem persisted.  While trying to map the LCD pins to the correct part on the motherboard, I used a continuity meter to map the pins.  It shorted one or both HM628512BLFP-7 SRAM chips (I think they are called BootROM RAM) and the motherboard did not want to boot, resetting every 3 seconds due to the power supply being shorted.  I then realized that the motherboard has a 3V lithium battery to keep some configuration alive and I passed the test probes over pins while they were powered by the Battery.  When I removed the SRAM chips, the board was back alive, but stopped with LED diagnostic code 2, and the manual says it is checking for BootRAM RAM, which of course were removed.  After soldering new SRAM chips, the motherboard booted correctly passing all the self diagnostics.  The LCD problem is still there, and I traced the problem to the Video RAM (HM514260CJ6) next to the Chips F65510 VGA controller (The controller seems to be OK because I can measure signals changing on all 8 bits that goes to the LCD).  I am waiting for the Video RAM chip to arrive and I will post the results
I bought the ESG mainboard from TK on ebay, to repair it. There were some more problems, most of them were easy to fix. One switching voltage regulator was shortet, and two transistors (display and green power LED) were shot.
But the lines in the display were still there.
After analyzing the protocol of the data transfer to the display, I was short before taking my logic analyzer. I even replaced the RAM chip a second time. But then I did some testing with removing signals to the display, and pulling the 8 lines to H one at a time. No result on bit 8.
Problem was a bent contact in the connector of the board to the LCD display! Looking back, it was obvious, because there came no signal for these lines out of the board. With black screen, alll signals were constant L. Pulling one of the 8 bits H there were white lines. But not on bit 8. It just had no contact to the display. But I was also sure that the problem came from the display controller or a bad display RAM chip. Key to the solution was to understand the display transfer protocol, which explained whyonly the lower half of the display was faulty.
The following users thanked this post: minsik, Samogon
Online TK
« Reply #36 on: February 09, 2019, 04:10:15 am »
I am glad you found the problem with the board and the display is now working.  Thanks for the follow up.
Online minsik
« Reply #37 on: March 18, 2024, 10:16:44 pm »
New (second hand) E4421B arrived and was told it "works good" by reputable dealer. Not so, the reference is faulty, being too high in frequency by about 200-300 hz as well as the external Ref says its unlocked! Damm.
Went whole hog in testing in stages and finally tracked down to the 10Mhz TCXO diagnosed as faulty. Dismantled and added a 1.5pf across xtal to tune. Reassembled and tested A1 and external ref now works 100.
Free run testing and the 10Mhz does vary about  3-5hz over cold to hot conditions. At least external Ref is fully operational at all times.
Problem solvered!
Unit destined for a fishing sinker is now pride of place in workshop.
« Last Edit: March 18, 2024, 10:46:00 pm by minsik »
Years of working with electronics. Now its just for fun.
The following users thanked this post: Fraser
« Reply #38 on: March 18, 2024, 11:42:29 pm »
This is the link to Mike's ( Mikeselectricsstuff ) teardown video (as requested per PM):
Nice find! I guess the output amplifier is still working? This was the biggest headache for the unit I used to own.
« Last Edit: March 19, 2024, 12:40:46 am by nctnico »
Online minsik
« Reply #39 on: March 20, 2024, 12:33:20 am »
Thanks nctnico.
I am very pleased with the outcome, a working E4421B! In my dreams I did not think to get this magnificent generator for so little money (relatively speaking)!
Yes all levels and all frequencies appear excellent as measured on a Siglent spec-an + FA-3 counter. This thing is beastly good. it reeks quality. So far its life was 34,400 approx hours, 200 power ups,  with lcd being on for 100% of the time. It must have been in a factory or long running in an assembly line or similar. I have turned on screen "light and text saver" and see a difference slowly coming. Even then LCD and backlight is good, maybe a slight yellowing.
I was able to win an eBay replacement reference module (same as mine, same xtal unit) that is on the way. So I can see if that is better or worse from my doctored one when it arrives. Also then it might allow some experimenting with changing the xtal to a OCXO. CCT seems to be able to cope with many differing mountings and types, sine-square etc. Only thing is if xtal is oven controlled I am not sure how it will react without enabling the "oven cold cct" (5 minute timer) in software, as I don't have any confidence/knowledge (treading carefully) in any software changing, yet!
Very chuffed I got a working good generator.
On any repair, "Never give up, never  surrender! (Galaxy Quest)".
Minsik.
Offline imaurente
  • Country: br
« Reply #40 on: April 16, 2024, 06:29:03 pm »
Hey guys!
I'm having problems with my 4421B, it simply doesn't activate the modulation, I hear the sound from the relay, but it doesn't work. It's like trying to activate modulation, but it doesn't, I've already done some tests:
1) I used the external modulation input and it worked well;
2) The OCXO is in order, 10mhz perfect and signal without imperfections.
One detail, about a year ago, my time base stopped working and I replaced it with the same one (ebay) and everything went back to normal, I don't have the service manual, if someone could make it available it would be of great help.
Note: The signal in blue and the attempt to modulate in FM (dev=100khz)
Hug!
« Last Edit: April 16, 2024, 06:32:35 pm by imaurente »
