Hi All...
I had two such gateways that were as unresponsive as you described...
I could get both back to life by taking inspiration from another place inside this blog (JiriB post)...
https://www.eevblog.com/forum/repair/e5810b-bricked/Below is the method I used to get/extract/prepare the two files needed to fix them ( MLO_XMODEM.bin and u-boot_YMODEM.bin )
Download the latest E5810B firmware from Keysight
https://www.keysight.com/us/en/lib/software-detail/instrument-firmware-software/e5810b-langpibusb-gateway-firmware-2426653.htmlUnzip the received B-01-07.zip, locate & copy the file e5810_B_latest_firmware.hex to your /home/user
(user being of course your username)
Sudo su
Check if you have binwalk installed by just typing binwalk
If not found, then apt install binwalk
binwalk -e e5810_B_latest_firmware.hex
This should have created a folder _e5810_B_latest_firmware.hex.extracted
Go inside this directory cd _e5810_B_latest_firmware.hex.extracted
ls -l You should see a file called 4A8B
binwalk -e 4A8B
This should have created a folder _4A8B.extracted
Go inside this directory cd _4A8B.extracted
MLO.hex and u-boot.hex are there: copy them to your /home/user
cp MLO.hex /home/user and cp u-boot.hex /home/user
Go back to your /home/user/ directory
cd /home/user
Process both files (As per JiriB procedure) respectively with:
dd if=MLO.hex skip=579 count=68240 bs=1 of=MLO_XMODEM.bin
and
dd if=u-boot.hex skip=123 count=264696 bs=1 of=u-boot_YMODEM.bin
Et voilà: you should now have the files required to go ahead with the remaining of JiriB procedure...
Attached is the E5810B UART0 Pinout (Baud Rate = 115200)
Best Regards...
