I have a few of these UPS failed over the years, all pretty much the same way. Power goes out, long enough to deplete the batteries, UPS shuts down, and refuses to turn back on ever again (yes, even with good fully charged batteries). On some of them no sign of life at all, on others when you press (and hold) the power button the fans come on and the "bypass" LED lights, but nothing else happens.
First and foremost, these were out of warranty, let alone any form of manufacturer support whatsoever, a long time ago. I've scoured the internet and have found absolutely nothing for schematics or any service information of any kind. Seems Eaton has succeeded in keeping this information a well guarded secret.
These UPS have a socketed daughter board that contains all the analog and digital control logic, so I swapped in a board from a known good UPS into the failed ones and sure enough, they all fire up and work normally.
So in all cases, the fault is on the control board and not on the power (main) board.
The control board has at its heart a TMS320F243PGEA digital signal processor, an Altera Max EPM7128STC100-15 CPLD (glue logic and perhaps has a role in PWM pulse train generation), some gate driver ICs, couple of ULN2003 drivers, and some op-amps for signal scaling/conditioning. Also a AM29F200BB EEPROM and 25080 SPI EEPROM.
So far, I've checked voltages, +5V nice and solid, no problem there. Checked that the TMS320's crystal oscillator clock is working, and it is (while the power button is being pressed down). No IC is getting abnormally warm, and I've scoped the output of all opamps didn't find anything much out of the ordinary there compared to a known good working board.
I'm really beginning to suspect a fault with the TMS320 DSP, or firmware corruption. For one, the behavior of the indicator LEDs does not match what is supposed to happen, the "bypass" LED is never supposed to come on all by itself without an accompanying fault indication, and buzzer going off constantly (buzzer makes no sound at all right now). Also even though the bypass LED comes on, power is never provided to the output at all.
The good news is... the board has a programming header for the DSP and I've mapped out all of the relevant JTAG pins. Bad news, I don't have a JTAG interface and wouldn't have a clue how to use it! Anyone familiar with the TMS320 DSPs able to lend a hand in how to diagnose one, would be much appreciated!
