Hello, I do have an eBox Lite Filament dryer. It works fine (display, buttons, fan) except that it's not heating. I experimented with replacing the NTC Thermistor with normal resistors to find out if the rest of the circuit is working. It turned out to be all ok except that the input value from the NTC seems to be much too high. And therefore it never starts heating.
The NTC is reacting to temperature changes, it starts with some 3 MOhm for 15 degrees, in the 60 degrees it's around 600 kOhm and for 100 degrees at some 300 kOhm.
With an adjustable resistor I found the values where the heater shuts off in the respective levels. The manual states the target temperatures of the hot plate which should be 61, 63 and 75 degrees celsius in the levels 1, 2, 3.
Level 1 (61 degrees): 15,47 kOhm
Level 2 (63 degrees): 12,56 kOhm
Level 3 (75 degrees): 8,98 kOhm
It starts to heat with an value slightly below 1MOhm, with an resistance of 1013 kOhm it didn't start to heat at all.
My question: How can I find a NTC to replace the existing one? I'm not sure where/how to search for it and checking some tables for 10K NTC's it doesn't match the values I need.
Looking forward to any suggestions!
