Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
ECU injector driver MOSFET replacement
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: ECU injector driver MOSFET replacement (Read 190 times)
nyogo
Newbie
Country:
on:
January 07, 2025, 10:08:32 pm »
Hi!
I'm repairing a Magneti Marelli motorbike ECU, one of the injector driver MOSFET is failing(L1N06C). The problem is that the MOSFETs used in these ECUs are obsoletes.
Original manufacturers were Motorola and Intersil/Haris:
- Motorola MLD1N06CL
https://alltransistors.com/adv/pdfview.php?doc=mld1n06cl.pdf&dire=_motorola
- Intersil 650036
Later Onsemi had MLD1N06CL
https://www.onsemi.com/download/data-sheet/pdf/mld1n06cl-d.pdf
but it's obsolete now.
Any idea what could be used as a drop-in replacement, because I see it's not a simple general purpose MOSFET.
Thanks!
Logged
mikerj
Super Contributor
Country:
Re: ECU injector driver MOSFET replacement
Reply #1 on:
January 07, 2025, 11:10:24 pm »
The STD70NS04ZL is a clamped MOSFET for automotive applications in DPAK, and is very similar to the part used to drive injectors in the well proven open source Speeduino ECU.
https://www.st.com/en/power-transistors/std70ns04zl.html
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
