Hi, all
I had been looking for an EDC CR103 for some time, for no real reason other than a fascination with precision low voltage/current circuits and I thought it might be nice to have a reference around for various projects and whatnot. These don't come up very often, so after waiting a while with no luck, I jumped on an MV!06 on eBay for parts or repair a few months back for about 80 bucks. It turned out that the repair was a simple broken solder joint in the divider switches and this thing was in spec. and has been rock solid ever since.
The other day a CR103 popped up on eBay for a similar price, so without much thought I grabbed that as well. This one was also for parts or repair but I thought it might be a good education. I should have mentioned that I'm a relative novice, but looking at the schematics I thought I could eventually get a grasp this and maybe repair if needed.
It turns out that the unit is basically functional. That is, it powers up and short of the decimal point lamps being out, all switches are functional and it produces output that is roughly where it should be. That said, this thing is nowhere near usable as the output has roughly 10mV of ripple at about 80KHz.
So heeding the advice that I see so often on these forums, I first checked the power supply for obvious issues and there are some. I'd like some help in understanding how or why these are present
I figure that many folks on these forums are familiar with these old EDC units, but for those who are not the manual, with schematics, is here:
http://exodus.poly.edu/~kurt/manuals/manuals/Other/EDC%20CR103%20Operating%20%26%20Service.pdfThe schematic for the power supply differs from the unit that I have in that the two 7x15 regulators are replaced by a single TO-66 package, RC4194TK dual-tracking +-15V regulator, datasheet here:
http://datasheet.datasheetarchive.com/originals/distributors/Datasheets-11/DSA-209651.pdfSo, on to what I'm seeing.
The output, as mentioned above has 10mV of ripple (for lack of a better term) at 80KHz
The rectified, unreglated voltages are roughly +- 32V, with ripple on each the positive and negative of about 380mV at 120Hz.
This is regulated down to +-24.5V with a pair of 1N5359 zeners, which is the input for the RC4194 regulators. The positive 24.5V input has about 8mV of ripple at 120Hz.
The negative 24.5V input, however is pretty horrible, with 400mV ripple or noise spikes, but the part that I'm not able to understand is that it's oscillating at about 80KHz. I'm assuming that it's oscillation from the regulator, but I don't understand how that is induced.
This is translating to the regulated voltages, which are roughly +- 16.5V, with about 70mV of ripple on the positive rail, again at about 80KHz, and a huge 3.15V on the negative rail at a head-scratching 50KHz.
Now being a novice I'm not well versed on voltage regulator operation, and I'm completely unfamiliar with this ancient dual-tracking regulator, so reading the datasheet doesn't really help me understand where this 80KHz is coming from, nor whether it's an issue with compensation of the regulator or filter capacitance on the input, some combination of the two, or something else entirely.
I'm perfectly willing to step through this on my own, piece by piece, but I would very much appreciate it if someone could point me to a good starting point to understand what's happening here. I'd hate to just start replacing capacitors or the regulator and fix the problem without understanding why it is happening. In software we call that programming by coincidence and it drives me nuts.
Thanks in advance for any help, and please let me know if I can provide more information to help you help me.
