The jumpwire thing or soldering a wire across blown fuse, or jamming in a glass fuse cheapie,
ALL THREE FIXES HIGHLY NOT RECOMMENDED may work for a responsible user with an inline external fuse/s of a similar value or lower,
to ensure a fast blow if a low current test goes south as they can do sometimes x lots...
WITH reminders on the meter to replace the fuse ASAP or yesterday
Fused leads are a winner too but ONLY if correct value HRC fuses fitted for the application at hand, otherwise the meter PCB becomes the fuse
LOL, please ignore this comment based on optimism
and just fit the correct fuse in the meter
Best to avoid Murphy scenarios and subsequent upcoming 2018 Darwin Awards as much as possible
