Ok so this is just the PSU section, and the B1 - B6 type stuff are just the HV rails right ? IDK how much tube currents change over the years, or their circuits, but what about those large wattage resistors R178 -181, I wonder if their value has changed much.
How close was the replacement transformer ? Do you know any before and after voltages ?
I have a 10W practice amp, I recently too it apart to learn a bit more about op-amp circuits, and there's only 1 dual op-amp in there, for the distortion circuit. So I've been looking at distortion pedal schematics, some day soon I'll try one, surely it will be better.
I don't need much volume, and I could add another speaker if I wanted to use a bigger transformer.
