At startup (power-on) and NO input signal, check the voltage drop on R13 (43 Ohm 2%) for about 0.6Vdc, Tunnel diode require a DC current flowing to be near the switching point (about 10mA), if the DC voltage on this diode is about 0.28Vdc this is probably OK.
