Hi all,
I have a multi chemistry AA-18650 charger and it is supplied with a universal voltage 12V 5A, 2-pin mains external adapter.
I get shocks from time to time whenever I touch the negative sping loaded pole whenever I try to load the battery.
I tried measuring the AC leakage by putting one probe on my finger and another touching the negative pole of the charger, the multimeter indicating ~100Vac. I am not sure if it's the rightway to measure the ac leakage but i did it anyway.
I tried measuring a USB port shield of my desktop PC it was ~6.6VAC.
I haven't tried breaking open the ultrasonic welded case of the smps adapter, is this worth fixing or should I just replace it. I have zero knowledge how these leakage works.
I have repaired plenty of smps so I know how to avoid fatal injuries when repairing them.
