Author Topic: Electric stove component  (Read 10849 times)
Offline KrishicallTopic starter
« on: March 04, 2024, 12:00:34 am »
Anyone have any idea what this melted component is? No help from the manufacturer. Thanks!
« Last Edit: March 04, 2024, 12:06:21 am by Krishicall »
Offline amyk
Re: Electric stove component
« Reply #1 on: March 04, 2024, 12:17:34 am »
5uF capacitor. I think this is an intact one: https://www.electroncomponents.com/image/cache/data/Capacitor/EC-MKP-X2-5UF-275V-AC-400V-DC-cooker-capacitor-500x500.jpg
Look for "induction cooker capacitor", these wouldn't be sold so prominently if they weren't common failure items...
The following users thanked this post: Krishicall
Offline tooki
« Reply #2 on: March 04, 2024, 12:18:28 am »
I truly don’t mean this to be rude, but if you cannot figure out what kind of component that is (resistor, capacitor, inductor, etc), given that both the component and PCB have markings that give it away, you probably shouldn’t be working on mains-powered equipment yet.
If your question is what value the component is, that’s a different matter.
Offline fzabkar
« Reply #3 on: March 04, 2024, 12:20:18 am »
« Last Edit: March 04, 2024, 12:33:12 am by fzabkar »
Offline cruff
« Reply #4 on: March 05, 2024, 01:37:56 am »
Did the capacitor fail due to heating caused by a bad connection at the screw terminal?
« Reply #5 on: March 05, 2024, 03:00:15 am »
Not sure, I havent taken it apart yet, but its probably too damaged to tell. I doubt it as the stove never moved and lasted several years.
Offline fzabkar
« Last Edit: March 05, 2024, 11:32:15 am by fzabkar »
Offline Gyro
« Reply #7 on: March 05, 2024, 09:59:44 am »
From the bulging, that capacitor self-healed a lot before it melted. it looks like runaway self-healing rather than direct heat from the terminal to me. Of course an intermittent connection could have caused lots of transients that could have killed it indirectly.
Given the power levels involved, that PCB needs serious rework (no image of the track side) in order to safely handle the high current. Likewise the wire termination.
Best Regards, Chris
