Author Topic: Electric Toothbrush: Guesstimate resistance  (Read 742 times)
Offline NivagSwerdnaTopic starter
« on: February 28, 2020, 09:24:31 pm »
OK... another repair fail... I have tried to replace the battery in my electric toothbrush and that part went well but it won't charge when on the base.
The unit charges via a coil of wire in the base which sits on a base station... I'm wondering if I broke something along the way..
... my question... What would you expect the resistance of the wound copper wire to be?  I measure 1.7 Ohms does that sound legit or could I have shorted the windings somehow?  It's just copper wire right?
PS
I wish I had measured it at the beginning
Offline shakalnokturn
Re: Electric Toothbrush: Guesstimate resistance
« Reply #1 on: February 28, 2020, 11:44:53 pm »
Looking at the spool 1.7 ohms sounds fine...
Don't you have a LC meter to throw on it?
What model is it? I have a Philips reject somewhere I may be able to check on.
« Reply #2 on: March 02, 2020, 11:30:41 am »
I actually discovered the problem.... the coil was fine but in the process of removing the PCB to replace the battery a small component had fallen off the board near the plastic retaining lug that hold the board in... I suspected something was up by looking at the appearance of the tiny pads... Anyway I made a huge guess and decided it was a diode that is missing somewhere around my house and had a go at replacing it with a SOD-323 Shottky I had in parts, slightly too big... but it fits and now it charges!
It works!
Moral of that story.... be very careful hinging out the PCB!
Offline james_s
« Reply #3 on: March 02, 2020, 05:11:19 pm »
Makes sense, there's gonna have to be a diode to rectify the output of the charging coil.
I had a toothbrush like that years ago. I was unsuccessful in getting it apart non-destructively so I replaced it with the much cheaper $20 Sonicare that uses ordinary AA cells that I charge externally. I swap the cells with a charged pair once a month and it's always good to go.
