Author Topic: Electro Instruments (Non Linear Systems related?) DVM  (Read 6952 times)
Re: Electro Instruments (Non Linear Systems related?) DVM
« Reply #25 on: July 19, 2016, 07:16:54 pm »
I came across an old Heathkit bench meter a whle ago that used a mercury button cell as a reference, but the cell had long before corroded away, and some previous owner had replaced it with the next best thing, a single LR44 cell, which of course was also dead and corroded.
Offline CubdriverTopic starter
  • Nixie addict
    • Photos of electronic gear
« Reply #26 on: July 19, 2016, 07:31:07 pm »
I recently got an HP 740B DC Standard/Differential Voltmeter and it has a dead mercury battery in it as a reference.  I need to figure out what to do to replace it at some point.
-Pat
« Reply #27 on: July 19, 2016, 08:58:41 pm »
LR44 and a shottky diode is a quick and dirty substitute, but if there is room put in a TLV431 and adjust it to the right voltage. 1.35V is within the adjustment range, though if you want a better one just take a LM10 and use it, which will give a buffered reference with slightly better performance, or at least improved PSSR.
http://www.ti.com/lit/ds/symlink/tlv431.pdf
Just remember not to use the TL431, very easy to confuse the 2.
  • Nixie addict
« Reply #28 on: July 19, 2016, 09:42:36 pm »
The mention of the reference got me searching on mercury battery substitutes, and I saw SR44 silver oxide button cells suggested as a possible alternative (with a series diode to drop the voltage) on several camera sites - apparently this chemistry has a relatively flat discharge curve similar to that of the old mercury cells.  However, seeing as the 740B is an old HP boat anchor, the installation of a TLV431 or LM10 and their associated support circuitry should not be a huge issue space-wise.  Thanks for the suggestions - more things to dig into.  (in my 'spare' time!!)
-Pat
Offline bob91343
« Reply #29 on: May 26, 2019, 10:02:19 pm »
Here is a pic of mine.
