Author Topic: High voltage power supply repair for cash  (Read 2151 times)
Offline ankurbTopic starter
« on: November 05, 2017, 03:53:50 pm »
High voltage power supply potential fixing?
If anyone is in the Los Angeles area and wants to help I can offer some money out of pocket. Honestly, don't want to kill myself trying to bite off more than I can chew trying to fix it.
Below are some pics.
Thanks!
Offline IRFP460
Re: High voltage power supply repair for cash
« Reply #1 on: November 05, 2017, 09:37:19 pm »
I'm pretty sure that's not a high voltage power supply but just the controls for one.
It's missing a transformer and all the other high voltage parts, i'd assume they're connected via that 8-pin connector on the back.
Trying to learn english, if I make any mistakes feel free to correct me!
« Reply #2 on: November 06, 2017, 01:36:45 am »
Hmmm not sure. Thanks. I'll ask around but I know it is an older style with vacuum tubes so older stuff.
Offline cdev
« Reply #3 on: November 06, 2017, 01:48:18 am »
Thats what I was thinking too. You have a control panel for a supply there.
Also, be aware that very high voltage is quite dangerous.
Note the very bright indicator light, lock, etc.
« Reply #4 on: November 06, 2017, 03:06:46 am »
Thanks for the info.
Looks like I'll stick to my previous setup with flyback.
Offline IRFP460
« Reply #5 on: November 06, 2017, 09:25:12 am »
That's true, it's an older model, but even with the magic of tubes you can't create high voltage without a transformer or something similar  ;)
Offline voltz
« Reply #6 on: November 06, 2017, 10:11:55 am »
A bit of searching came up with this:
Field Emission Corp High Voltage Supply Model 3145
Have to agree, it looks like a controller for a larger system. The main give-away is there are no high voltage terminals to be seen anyway other than a multi pin cable connector. The unit probably connects to a main generator unit which then does all the high voltage stuff.
Offline Johnny10
« Reply #7 on: November 06, 2017, 11:07:15 am »
What kind of tube is in the third down pic?
IMG_1480
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
« Reply #8 on: November 06, 2017, 01:44:47 pm »
The tube is labeled Amperite 115N010T delay relay.
