hello everyone ,
i have a ultrasonic cleaner from the brand EMAG in germany , the type of unit is the EMMI 40 HC
now the problem is that the electronic circuit is deffect ,,,,the are two FET'S IRFP 460 L on the board that where blown .
i replace those FET'S and the unit stil don't work ?
so i concentrate on the one 16 DIP IC that i think is also deffect ,,but the identification number is scratched of by the manufactor
can someone help me with this to figure out what kind of IC is needed for this 38 khz cleaner ...
i found some number stil readable and looks like 44 number ..it has to be a oscilator IC in the 38khz range
the output of the ic i found that it drives two transistors one pnp and one npn .
i know that the ic has a vcc + on top (next to notch) and ground at other side over length of ic
also the output pins are on the oposite site of vcc
can anyone help ?
thanks rene van steenis
