Author Topic: GW Instek GOS-620 schematic needed  (Read 1321 times)
Offline SylviTopic starter
  • Country: eg
« on: September 23, 2018, 11:37:56 pm »
Hi
I have a GW Instek GOS-620 20MHz analogue oscilloscope that is six months out of warranty and I would like to get the schematic for it. Does anyone have one or know where to find one?
Instek has discontinued this unit from what I understand, replacing it with its bigger brother which has a built in multimeter and component tester or other stuff.
My scope has a problem in the vertical positioning for both channels. If there is a small sine wave (2-divisions peak-to-peak) in the lower half of the display and I sweep it upward using the vertical position control, the wave gets smaller until it is a flat line about three-quarters of the way up. If the sine wave is a bit larger, it will be okay at the bottom of the screen but as it is swept upward the top half distorts then clips.
I suspect the problem will come down to a bad solder connection in the vertical offset circuit.
I ordered a new DSO which might be here in a week or two, after which I can open up the Instek and work on it with impunity.
Offline tautech
Avid Rabid Hobbyist
  • Country: eg
Re: GW Instek GOS-620 schematic needed
« Reply #2 on: September 24, 2018, 04:02:36 pm »
THANK YOU !!!! ;D
