Author Topic: elektronikon reprogramming  (Read 6639 times)
Offline usefi5961Topic starter
  • Country: iq
« on: January 19, 2019, 06:22:30 pm »
dear members:
please help me about atlas copco elektronikon ga90 vsd with p.n:1900070102ed01.
the system failure 20 appear in display,i don't know this message error,but i think checksum error is happened and data of time keeper m48t02 missed.in some forum read that elektronikon need reprogramming with elektronikon software (DFM4WIN)but this software not found in web's so i need data files for this elektronikon controller with the same version .please if everybody have binary files for chips of this controller (m48t02-at28c64-m27c256 and m28f101)send me or share it in this forum.
thanks
« Last Edit: January 19, 2019, 06:36:54 pm by usefi5961 »
Offline montarbo
Re: elektronikon reprogramming
« Reply #1 on: January 24, 2019, 07:02:46 pm »
System failure 20 mean two things.
First DC Over Voltage and second Earth fault so, verify wiring. If nothing obvious contact Atlas Copco.
Offline cs.dk
« Reply #2 on: January 25, 2019, 06:38:01 am »
If the stupid timekeeper IC battery dies, the compressor will show error 200, not 20.
I've had a topic on the subject long time ago, another member sent me a PM, about flashing the device;
Even if you put new one or copy one chip reprogramming of the whole elektronikon is needed because they have security and parity test inside every ROM.
  • Country: iq
« Reply #3 on: January 25, 2019, 07:31:46 am »
thank you very much for reply,sorry do you have data files of atlas copco products(such as ga90 vsd,)?
and do you have manual of software for elektronikon controller?
Offline montarbo
« Reply #4 on: January 25, 2019, 06:10:23 pm »
No programming for your unit is possible by any third part. Only A.C or a registered repair agency.
  • Country: iq
« Reply #5 on: February 01, 2019, 07:54:04 am »
sorry,have anyone instruction manual for dfm4win software?please if anyone have it share or send me.
thank's
Offline nemos
  • Country: gr
    • repairtronics
« Reply #6 on: June 03, 2019, 10:11:06 am »
"No programming for your unit is possible by any third part. Only A.C or a registered repair agency."
Never say Never , ;) I can if you need send me a message
Offline tuju
  • Country: ee
« Reply #7 on: February 20, 2020, 01:35:57 pm »
I'm actually trying to do the same. I've Elektronikon I and it's broken, it doesn't pull GA7FF screw relays that control the contactors. I replaced the darlington array between the HC08 and the relays, but still the same problem. It looks like the HC08 i/o line that drives the relays is just dead, it never changes its state.
Before I replace the MCU, I would need to get the flash, EEPROM and probably other nv-mem content (hour counters, settings) before I replace the MCU. I'm trying to read it through MON08 interface, but did not manage to connect yet with in-circuit BDM.
I guess the unknown variables here are:
- device power for HC08 during MON08 connection: system or MON08 connection?
- security code
- connection parameters (clock supply, divider, HC08 sub-type etc)
Already did some preliminary debugging from MON08 connection during attempts and it's voltages seemed to be expected. Maybe my data-pin is fried too - or I'm doing something really wrong here.
At least I've learned a lot while getting this far, regardless the final result. :)
Offline electronicmechanicfinland
« Reply #8 on: May 10, 2024, 02:31:53 pm »
Just fixed one.. replaced timekeepper battery and reprogrammed eprom with universal programmer and final programming with atlas copco software 4 windows. If this case is still open i can help you
