Author Topic: elektronikon reprogramming  (Read 7048 times)
Offline usefi5961Topic starter
  • Country: iq
« on: January 19, 2019, 06:22:30 pm »
dear members:
please help me about atlas copco elektronikon ga90 vsd with p.n:1900070102ed01.
the system failure 20 appear in display,i don't know this message error,but i think checksum error is happened and data of time keeper m48t02 missed.in some forum read that elektronikon need reprogramming with elektronikon software (DFM4WIN)but this software not found in web's so i need data files for this elektronikon controller with the same version .please if everybody have binary files for chips of this controller (m48t02-at28c64-m27c256 and m28f101)send me or share it in this forum.
thanks
« Last Edit: January 19, 2019, 06:36:54 pm by usefi5961 »
Offline montarbo
Re: elektronikon reprogramming
« Reply #1 on: January 24, 2019, 07:02:46 pm »
System failure 20 mean two things.
First DC Over Voltage and second Earth fault so, verify wiring. If nothing obvious contact Atlas Copco.
Offline cs.dk
« Reply #2 on: January 25, 2019, 06:38:01 am »
If the stupid timekeeper IC battery dies, the compressor will show error 200, not 20.
I've had a topic on the subject long time ago, another member sent me a PM, about flashing the device;
Even if you put new one or copy one chip reprogramming of the whole elektronikon is needed because they have security and parity test inside every ROM.
  • Country: iq
« Reply #3 on: January 25, 2019, 07:31:46 am »
thank you very much for reply,sorry do you have data files of atlas copco products(such as ga90 vsd,)?
and do you have manual of software for elektronikon controller?
Offline montarbo
« Reply #4 on: January 25, 2019, 06:10:23 pm »
No programming for your unit is possible by any third part. Only A.C or a registered repair agency.
  • Country: iq
« Reply #5 on: February 01, 2019, 07:54:04 am »
sorry,have anyone instruction manual for dfm4win software?please if anyone have it share or send me.
thank's
Offline nemos
  • Country: gr
    • repairtronics
« Reply #6 on: June 03, 2019, 10:11:06 am »
"No programming for your unit is possible by any third part. Only A.C or a registered repair agency."
Never say Never , ;) I can if you need send me a message
Offline tuju
  • Country: ee
« Reply #7 on: February 20, 2020, 01:35:57 pm »
I'm actually trying to do the same. I've Elektronikon I and it's broken, it doesn't pull GA7FF screw relays that control the contactors. I replaced the darlington array between the HC08 and the relays, but still the same problem. It looks like the HC08 i/o line that drives the relays is just dead, it never changes its state.
Before I replace the MCU, I would need to get the flash, EEPROM and probably other nv-mem content (hour counters, settings) before I replace the MCU. I'm trying to read it through MON08 interface, but did not manage to connect yet with in-circuit BDM.
I guess the unknown variables here are:
- device power for HC08 during MON08 connection: system or MON08 connection?
- security code
- connection parameters (clock supply, divider, HC08 sub-type etc)
Already did some preliminary debugging from MON08 connection during attempts and it's voltages seemed to be expected. Maybe my data-pin is fried too - or I'm doing something really wrong here.
At least I've learned a lot while getting this far, regardless the final result. :)
Offline electronicmechanicfinland
« Reply #8 on: May 10, 2024, 02:31:53 pm »
Just fixed one.. replaced timekeepper battery and reprogrammed eprom with universal programmer and final programming with atlas copco software 4 windows. If this case is still open i can help you
Offline lencza
« Reply #9 on: December 19, 2024, 03:04:03 am »
Hi electronicmechanicfinland can you help me to find software and tell how to upload and download project and files from one Elektronikon MK5 controller to other new blank one?
I have two the same compressors A.C. and we had an issue with one controller, so company ordered new unit, but this came blank, the message is showing "NO PLC application loaded"
If its possible to upload the apps and project from one which is still good, to this new one? Please help :)
or somebody else can help me?
