(1)The psu does nothing now and I also tried the jumper between green and black and nothing at all. Does fan of this psu rotate? If not, the psu has gone. Normally, this
fan will rotate once green wire is shorted to ground.
(2)The standby voltage from the purple wire is fine and it stays at 5v. This means 5V supplied to chips controlling psu. If your mouse has led, it lights up.
(3)The green wire it has only 2.3v and that is a residual voltage as it will go to 0.8v. I encountered once, may be bad contact. Put the red probe deep into the connector
hole with green wire and move red probe forwards and backwards, black probe clamped to the psu chasis/casing, then switch on the computer to see if the voltage drops to
zero. If voltage drops to zero, computer switches on.
