Hi everyone.
I was given an Elma S30H ultrasonic cleaner - which would really help me in my part time job of cleaning up and polishing jewellery. It's an expensive machine, but the jeweller who gave it to me said it stopped working, and if I can fix it I can have it - it's worth over £600 so I'm eager to fix it if I can, since it would be a quality tool for me to use.
Symptoms:
So, I turn it on and initially it seems to work. I can here the ultransonic transducer doing its thing, the heater, degas, sweep and timer functions all work.
After about 20s the sound from the transducer starts fading in and out, then 10-20s later it stops, and the indicators on the front of the unit show a "running light" on the timer leds.
The service manual says "There is a fault on the PCB control, on the connection betweenultrasound >> transducer system or on the transducer system." (see the service manual page 19 here:
https://www.manualslib.com/manual/1596103/Elma-Elmasonic-S-Series.html?page=19#manual). Since the transducer works, initially at least, I'm guessing there's a problem on the control board itself. Their advice somewhere else in the manual: send it back to be fixed - not what i want to do since i have little money, and anyway, where's the fun in that? Similarly, new control boards are available to buy, but at over £100 I don't want to do that either and so have been trying to figure out what is wrong myself.
As far as I can see visually, there is nothing burnt out or obviously disconnected. The solder joints seem fine, and I have tested the caps which are all ok.
There is a small 8 pin surface mount chip by what I presume are power transistors on a big heatsink which you can see on one of the images I have attached. It is an L6384ED, a high voltage half bridge driver.
Could this be the issue?
I could get a new one for a lot less than a new board and although I might not be able to solder it on neatly, I'm sure I could do a good enough job but I would really like some other opinions as what the cause of the problem might be, or what else I should be looking for, before I start ordering parts.
Thanks for your help.
