Author Topic: Elna Lotus (vintage) sewing machine manual  (Read 2128 times)
Offline ShockTopic starter
« on: March 06, 2017, 12:39:08 am »
https://www.scribd.com/doc/3714035/Elna-Lotus-Instruction-Booklet#
Anyone got access to download this manual? Please add it as an attachment or provide an alternative link.
Offline amyk
Re: Elna Lotus (vintage) sewing machine manual
« Reply #2 on: March 06, 2017, 01:45:14 am »
Wrong manual, the one I need is in the link I posted.
« Last Edit: March 06, 2017, 01:48:53 am by Shock »
Offline amyk
« Reply #3 on: March 06, 2017, 04:03:58 am »
http://d1.scribdassets.com/ScribdViewer.swf?document_id=3714035&access_key=key-jpqj2p6p9yqogup6pmc
You can click "Print" and then use your system PDF driver to output a file. It is 14MB, which I cannot attach because it is too big, but you should be able to do the same.
