Author Topic: ELSEMA gate opener crystal  (Read 1419 times)
Offline highflyer83Topic starter
« on: September 15, 2019, 12:49:38 am »
Hello all,
I have a couple ELSEMA gate openers with a common problem, the legs on the through hole crystals keep cracking and breaking.  I'm trying to order a handful of spare crystals to have on hand for when this happens, but having trouble with this.  The crystals that are broken are labeled "6.786 KDV3Z" but I can't find anything online that has this same label.  Any thoughts as to where to get these?  Assuming I can get these crystals, my thought is to solder the new ones onto the FOB boards then apply a dab of hot glue or similar to try to have them last longer, that should be fine hey?
Thank you.
Offline fzabkar
Re: ELSEMA gate opener crystal
« Reply #1 on: September 15, 2019, 05:11:11 am »
Could we see a photo?
« Reply #2 on: September 15, 2019, 06:34:07 am »
For sure, try this one https://drive.google.com/open?id=1CIb1k7D-3IBmrgB4uL6sFHlchTADfDdx
You can make out the broken legs, one is easy to see, the other is just left of it going towards that IC with scraps of old glue/tape on it, that was holding the crystal.
Offline L_Euler
« Reply #3 on: September 15, 2019, 01:17:37 pm »
Solder the new one in with a couple leg extensions so they can flex a bit.
There's no point to getting old if you don't have stories.
« Reply #4 on: September 15, 2019, 10:14:54 pm »
The challenge is finding "the new one." How exact does a replacement need to be as far as its labeled frequency?  I can't find this exact number anywhere.
Offline fzabkar
« Reply #5 on: September 15, 2019, 10:25:02 pm »
When I needed a special crystal decades ago, I had one custom cut by Hy-Q.
https://hy-q.com.au/crystals/index.htm
https://hy-q.com.au/pdf/Hy-Q%20Crystal%20Data.pdf
One other solution might be to replace the crystals in the transmitter and receiver with more commonly available matched pairs.
« Last Edit: September 15, 2019, 10:40:01 pm by fzabkar »
Offline fzabkar
« Reply #6 on: September 15, 2019, 11:56:19 pm »
https://en.wikipedia.org/wiki/Citizens_band_radio
I suspect that the crystal frequency may be multiplied by 4 to give 27.144MHz.
A frequency of 27.145MHz is assigned to Radio Control Radio Service (RCRS) channel 15A.
Edit:
If you multiply by 64, the frequency becomes 434.304MHz.
434.300 MHz is channel 50 in the LPD433 band.
https://en.wikipedia.org/wiki/LPD433
"LPD is also used in vehicle key-less entry device, garage or gate openers and some outdoor home weather station products."
« Last Edit: September 16, 2019, 12:23:43 am by fzabkar »
The following users thanked this post: highflyer83
Offline L_Euler
« Reply #7 on: September 16, 2019, 12:13:57 am »
« Reply #8 on: September 24, 2019, 02:33:17 am »
That is what is happening.  There is a ICS501 set up to give 4x multiplier on the crystal.
