Hello everyone. I'm a long time reader but I posted very little on here.
First of I apologize in advance for my English, I'm not a native speaker and I hope that my post is at least readable.
I have a fairly old but still capable Enermax branded EGA1000EWL atx power supply. This came from my main workstation and was replaced some years ago with a more modern one after developing a fault. That's a short summary of what happened and what I did back then:
The PC was hooked to refused to start, and the indicator led on the back of the unit was red. At this point I replaced the PSU with another one and the PC was fine.
With the PSU out I checked for obvious signs of damage and upon inspection I found some bulging capacitors (as expected given the age...). I replaced every filter capacitor in the unit with brand new Rubycon low esr parts and tried to power the thing back on.
The PSU would start fine (5VSB is there and healthy, back led orange-standby) but when I tried to fully turn it on it refused to start. I can hear a relay click and for a short moment I can see the 5V and the 12V rails turning on but they immediately shut off and the back led turns red again. This is a smart PSU so it has a buzzer for error codes, according to the manual there is something wrong with the protection circutry.
The protection circuit in this PSU is on a daughterboard, on it I can see no obvious signs of damage. The main control IC is a PS232S from SITI, on board there is also a simple opamp.
Some time ago I dug out this PSU from storage and it behaves exactly as I remebered, I would really like to repair it, if not just to learn something new.
I have a fairly good ammount of test equipment and I'm familiar with working with high voltage and electronics (Soon to graduate in physics) but I don't have any expertise on actual power supply design so I don't know how to approach the problem.
I attach here the link for the datasheet of the IC and a review/teardown of the PSU in question.
http://www.siti.com.tw/product/spec/Power/SP-PS232S-A.003.pdfhttps://www.hardwaresecrets.com/enermax-galaxy-1000-w-power-supply/https://www.jonnyguru.com/blog/2006/08/15/enermax-galaxy-ega1000ewl-1000w-power-supply/I hope you can provide some feedback on how to solve this fault
Thank you in advance
