This is a new thread under the repair section which attempts to summarize different information, topics from two earlier threads discussing P5205 and P5210 probes under test gear section
https://www.eevblog.com/forum/testgear/tek-p5205-hv-differeantial-probe-teardown-btw-what-are-the-red-and-brown-wires/ and
https://www.eevblog.com/forum/testgear/repair-tektronix-p5210-high-voltage-differential-probe/As of today, there does not seem to be any service manual on internet explaining how to calibrate these probes but only a manual showing performance verification. Both P5205 and P5210 seems to have about similar amplifier circuit except the main High Voltage part, see attached different pictures comparing both probes (top and bottom PCB).
One of my P5210 was calibrated prior purchase to USA at Advanced Energy Industries, Inc and the second P5210 purchased at eBay-Turkey had a problem. Initially with the 2nd probe there was no signal at all then later I did found a soldering issue in the high voltage potted part so did reflow the connector line. Good news: it was then probing OK except the calibration issue discussed on test gear thread. In short, I could not get same gain output between the two when sensing 250 KHz induction 250W ballast output. At that time, I was only testing both probes with my tek 2465 oscilloscope to discover the mismatch gain but never thought to try out other frequencies.
This week-end I thought to use my good old tektronix PG506 section, specifically the High Ampl mode to generate circa 18V at different frequencies (100Hz, 1KHz, 10KHz, 100KHz and 1MHz), both probes with 100x mode. The probe which is working OK seems to offer a flat square output at these frequencies, see the result from my TDS540C screenshot attached. However with the partially failed or needing complete calibration probe, some screen shots shown partial overshooting or non-flat frequency response, what is clear the gain is not flat for some reason.
Ch 1 is direct output from PG506, Ch 2 the good P5210 and Ch 3 the partial fail P5210
Unless another part or component of the circuit is failed, it seems there are a total of 4 variable small brown capacitors, Common Mode Rejection blue potentiometer, white gain potentiometer and two other grey potentiometer (no idea what are their use or function) for the calibration. Would any of you know the exact steps to calibrate the probe or what troubleshooting method to follow ?
Thank you in advance, Albert
