Author Topic: unknown chip needs information  (Read 1021 times)
Offline james101Topic starter
« on: May 03, 2021, 11:46:02 pm »
Hi there im trying to find a data sheet or know what this chip is
this is unknown
its from a charger unit i have.
can anyone help us out or know where to get a data sheet PDF
or somewhere that would sell these chips
thank you
Offline dc101
Re: unknown chip needs information
« Reply #1 on: May 04, 2021, 12:29:13 am »
Maybe this? https://datasheet.lcsc.com/szlcsc/2009231805_GigaDevice-Semicon-Beijing-GD32E230K8T6_C712540.pdf it actually comes in a tssop20 although it seems unlikely.
Can you try taking another photo at a different angle, maybe try and cut down the glare on the chip so we can better read the printing? Some pictures of the surrounding board might help as well.
Also, do you have a part number or name of the charger, what does it charge?
Cheers
-Tim
« Last Edit: May 04, 2021, 12:37:42 am by dc101 »
The following users thanked this post: james101
Offline amyk
« Reply #2 on: May 04, 2021, 03:07:15 am »
APT32F003F6P6
Despite this clearly ST-inspired part numbering, this is NOT an ARM but "C-SKY" core, which is basically another MIPS clone.
The following users thanked this post: dc101, james101
Offline dc101
« Reply #3 on: May 04, 2021, 03:13:14 am »
Good eye! I didn't see the 3 after 32F00.
« Reply #4 on: May 04, 2021, 03:42:27 am »
hi thanks for helping us out is there a English data sheet at all
is it possible to get this chip at all being a clone.
thanks all
« Last Edit: May 04, 2021, 03:46:17 am by james101 »
Offline dc101
« Reply #5 on: May 04, 2021, 04:20:52 am »
It's unlikely that you would be able to find an exact replacement for it without having to purchase another charger. Perhaps you could explain what you're trying to accomplish so that we can help you? I would say to dump the flash of the existing chip, but not knowing the condition of your current chip, or what you're actually trying to achieve, it's hard to suggest anything.
« Reply #6 on: May 04, 2021, 04:36:59 am »
its pointing out that the current chip possible has a  short on it.
looking at the data sheet should give me some ideas.
charger does not wake up
everything else checks out to be working fine
except this chip.
i been checking for a replacement and not having much luck,
the charger is unknown model as its going under all different names
there no marking inside or model number.
« Last Edit: May 04, 2021, 04:40:14 am by james101 »
Offline dc101
« Reply #7 on: May 04, 2021, 02:34:16 pm »
The datasheet points out the chip has SWD support. If you have a JTAG adapter that supports SWD, you might be able to dump the flash ram from the chip. That is of course assuming that the chip still functions/flash is not corrupt, and that no fuses have been blown to prevent reading the flash memory.
There are development boards available for this MCU that appear to also contain a small SWD programmer http://en.aptchip.com/article/MCUdevelopmentboard You could use the SWD programmer to dump the flash from your MCU, then program the new MCU on the board, remove it from the dev board and replace your MCU.
« Reply #8 on: May 04, 2021, 10:05:51 pm »
thank you for the information i emailed the company to see if they send overseas.
looks like there a short on the chip.
trying to source a replacement.
thank you for all your help
