Author Topic: LG TV T-CON board help  (Read 492 times)
Offline raf11011Topic starter
« on: December 12, 2023, 03:37:14 am »
I need to replace the T-CON board in my lg tv. I have found this one. Can anyone that knows more about these board than me (literally no knowledge at all) tell me if the replacement board will be compatible?
My board is the one with the ribbon cables attached. Replacement board is on dark surface.
Offline m k
Re: LG TV T-CON board help
« Reply #1 on: December 16, 2023, 04:18:19 pm »
It's pretty close.
Can't see the exact model type of the replacement board.
Much is programmable, so probably much must be programmed after a change also.
Do you know that replacement is ok?
Its center has been hot, maybe even not healthy.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
