So I managed to pick this up used and abused. It has a few problems
someone badly abused it. The 1ohm range, 10ohm range and 10k ohm rage are the worst.
20kohm range has one open circuit 20k wire wound at position 8. The 10 ohm range has the second resistor overheated and indicating 19.789ohm, first 10 ohm is spot on.
The 1ohm rage has a few problems, 4 to be exact. 2 of them were really fried, pos 1 reads 1.914 and second one on pos 4 reads 19.784 ohm.
So now searching for the following precision wire wound resistors with low tempco (not easy to locate secondhand):
20.0k ohm
4 of 0.2 ohm
2 of 2.0 ohm
Any help or advice appreciated. I would like to restore this to close to factory specs. All measurements were very repeatable in 4 wire mode.
Regards and thank you.
