Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
FSFR2100 SMPS Repair
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: FSFR2100 SMPS Repair (Read 1891 times)
dundee
Regular Contributor
Country:
on:
June 17, 2016, 09:05:40 pm »
Hi Guys!
Im trying to repair a SMPS based on a FSFR2100.
Datasheet:
http://www.promelec.ru/pdf/FSFR2100.pdf
It is part of my Audio-System (no schematics available).
Actual Situation:
-Standby Voltages OK
I get 25V at the output without load. It should be 32V. If i connect a load the voltage goes down to 20V (if i draw 700mA).
Any ideas, what could be the problem?
Pictures Tomorrow...
Logged
tautech
Super Contributor
Country:
Taupaki Technologies Ltd. Siglent Distributor NZ.
Re: FSFR2100 SMPS Repair
Reply #1 on:
June 18, 2016, 01:27:32 am »
How are you measuring voltages, a DMM I'd guess but have you checked for excessive ripple, the frequency of which may exceed the capabilities of your DMM.
So blindly going forward, check secondary side caps, diodes and possibly the feedback opto.
Logged
Avid
Rabid
Hobbyist.
wraper
Supporter
Country:
Reply #2 on:
June 18, 2016, 01:35:46 am »
IMO either electrolytic capacitors on the secondary side are dead or something wrong in the feedback loop.
Logged
dundee
Regular Contributor
Country:
Reply #3 on:
June 18, 2016, 10:31:16 pm »
I changed all primary and secondary electrolytic caps.
I measured 1Vpp Ripple at the 320V behind the rectifier.
I'm wondering about that. I changed the two 330uf/200V caps against new ones.
Could they be the problem?
Here can see the supply in original condition:
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
