All,
I'm attempting to repair a faulty fan control circuit on a computer ATX PSU (Antec TP3-550). Attached is a schematic I did, but I'm pretty sure it's wrong. The transistors are guesses (pretty sure the top NPN is right, but the bottom NPN, I think, is wrong. The program I used didn't have a icon for a thermistor, so I just dropped in a pot. Anyway, the thermistor at "room temp" reads 5.5k. As the power supply heats up, the fan should increase in speed. Right now, the fan doesn't run at all (so I'm guessing one of the BJTs is dead), but I was trying to figure out the circuit before I just started pulling them. I also fully admit one of them (or both) may be a FET, but that doesn't seem right for a fan control (since BJTs are easier to operate linearly, especially with a "dumb" circuit like this.
Please, I need input here, because right now, nothing I do seems to allow me to control the fan speed with the thermistor (guessing because that top BJT is just saturated, and the fan provides an easier path to ground than the lower one, but that makes no sense).
Thanks!
