Hello
Does anyone happen to have the service manual or schematics for this old (1970's?) function generator?
(Exact Electronics Function Generator 506)
It's lighting up nicely, but the outputs are dead. When measuring the circuit I see the transformer working, but 0 volts on the pcb entry points labeled + and - 12. I unscrewed the big smoothing caps, and they also seem to be working fine - though their capacitance is larger than it says on the component (3900 instead of 2700 uF). I'm thinking maybe a burned out diode is shortening the regulated power outputs to ground?
Either way the schematics would be a huge help
Cheers
Klaus
