Author Topic: Yamaha DX 7 overheated and no sound  (Read 2196 times)
Offline thomastormTopic starter
  • Country: gr
« on: July 10, 2016, 08:32:27 am »
Hi everybody
I forgot to switch off my DX 7 for days and i found it overheated and with no sound.
What can i do now?
Thanx
Offline Totalsolutions
Re: Yamaha DX 7 overheated and no sound
« Reply #1 on: July 11, 2016, 08:35:30 am »
Hi, Mk II .... ? Not much to go on. Have you checked the PSU (power supply unit), if its that old a keyboard and has a external power brick more likely the transformer overheated only, open circuit to the internal thermal fuse.
Sent from my GT-N7100 using Tapatalk
Paul
« Reply #2 on: July 11, 2016, 08:39:08 am »
Check out youtube  user "fredturd" Yamaha DX 7 Battery Repair  Tips #1
« Last Edit: July 11, 2016, 08:45:21 am by Totalsolutions »
Paul
Offline Jr460
« Reply #3 on: July 11, 2016, 11:02:18 pm »
Is this a DX7 or the DX7IID/DX7IIFD?
Years ago I had my 1987 DX7IID go dead.  Power supply was the issue.  The local repair shop really didn't want to touch it but said most likely the big 5W resistor in PS opened up, it was a common fault.  The supply is internal, a separate module from everything else in t he unit.  Even the original DX7 didn't use a wall wart/plug pack.
Opened it up, measured, and sure it was open.  I forget the value of it, something like 2.5 Ohms 5W.  I could find that exactly but found to resistors at 5W that paralleled was very close to the value I needed.  Whacked it in, and it has been working fine for the past 15 years or more.
Offline bitseeker
« Reply #4 on: July 12, 2016, 01:59:22 am »
Correct, internal power supply. That's the best place to start the investigation on most dead devices, keyboards included.
