Use compressed air, blow away all the dust [outdoor] especially at the areas of arching. Then use WD40, spray at the areas of HV.
Check if there are still arching.
Be careful high voltage, discharge capacitors, make sure take many photos before you blow things out of place. If you are not certain, let the pro do it.
