Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
F27 resistor value
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: F27 resistor value (Read 1151 times)
montarbo
Contributor
F27 resistor value
on:
March 17, 2019, 08:24:18 pm »
Hello,
Thanks a head for help with SMD resistor value. A code F27 on the resistor itself.
Logged
shakalnokturn
Super Contributor
Country:
Re: F27 resistor value
Reply #1 on:
March 18, 2019, 08:10:48 am »
Size, circuit context and maybe a photo would be helpful.
Any way it could be a fuse?
Logged
montarbo
Contributor
Reply #2 on:
March 18, 2019, 11:41:06 am »
1812 package and its in PSU mains input to an industrial LED light, there are two of these in series with a TH (green, black, silver, gold, blue), ie
F27--TH as above--F27. Both the F27 are fried.
Logged
montarbo
Contributor
Reply #3 on:
March 20, 2019, 07:35:45 pm »
Any ideas???
Logged
shakalnokturn
Super Contributor
Country:
Reply #4 on:
March 21, 2019, 06:28:58 pm »
Check if there is a fuse anywhere else.
Is TH a NTC thermistor? What power is the light?
With no better clues I'd throw in a couple of 27
fusible resistors.
Logged
SiliconWizard
Super Contributor
Country:
Reply #5 on:
March 21, 2019, 08:28:16 pm »
If this is indeed a resistor, this should be a 12Mohm, +/-5% resistor.
See here for SMD resistor marking:
http://www.marsport.org.uk/smd/res.htm
Logged
shakalnokturn
Super Contributor
Country:
Reply #6 on:
March 21, 2019, 11:52:21 pm »
12M
on the power input that's not going to fit...
Maybe TH is trough-hole, in that case the TH would be an inductor.
An inductor and series resistor is a common setup on the input of cheap SMPSs. I'd still stick to 2x 27
but check power consumption and size of bulk capacitor.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
F27 resistor value
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
