The TV worked over a week without losing channels when I found a firmware update...
I could not resist and installed it as decribed.
I copied the 2 files to a USB thumbdrive and switched the TV on.
The message "upgrade in progress" and a green progress bar appeared on the screen for a few minutes.
When the progress bar reached the right end, the message "rebooting" appeared and the screen turned black immediately.
I waited several minutes, but the screen stayed black.
The update description said "don't switch off" and "don't touch the remote control". But what else could I do?
So I tried to switch the TV off (and on) using the remote control, but nоthing happened.
Now I tried to pull the AC plug and pushed it back again - again nothing happened.
I tried to turn on the TV using the remote control - nothing happened.
I tried to enter the service menu (code 123654) - nothing happened.
I think I brickеd the TV successfully.
Does anybody know, how to rescue the device?
