Hello, I am trying to repair a Eckman hedgtrimmer. I have found the fault that appears to be the ZHQ microswitch (see attached pix).
I am somewhat of a novice with micro switches but to confuse matters this has 2 mini buttons that are triggered by the plastic button in the housing. When I press one of them the unit works, when I reinstall the plastic button and casing (which presses both of them together) it does not work. I assume a failed switch?
Also why are there 2 buttons on the micro switch! is this a fail safe?
And also can anyone recommend a suitable replacement I might be able to get in the UK/Europe as I cannot find ZHQ switches for sale in the UK. It is a ZHQ ZQ7 12/1.
Thanks in advance!
