Author Topic: Fan for UPS  (Read 2112 times)
Offline Lord of nothing
  • Country: at
Fan for UPS
« on: November 26, 2015, 12:08:50 am »
The Fan got louder over the Time. Normally for other Stuff I take Pc Fans but on this Time not a god idea.....
Original Fan: http://www.nmbtc.com/fans/part-numbers/DC-Axial-Fans/3110KL-04W-B50-G00/3869
Can someone recommend an Silent Fan?
The Major Problem is a 2Pin Connector and the cable must be short <10cm and there are a lot of Hot and 230V Parts around.
THX!
Made in Japan, destroyed in Sulz im Wienerwald.
Offline Monkeh
Re: Fan for UPS
« Reply #1 on: November 26, 2015, 01:05:17 am »
Why not?
It's a 12VDC fan, in a standard size..
  • Country: at
Re: Fan for UPS
« Reply #2 on: November 26, 2015, 01:23:13 am »
a pc fan dont have to much power.
Offline Monkeh
Re: Fan for UPS
« Reply #3 on: November 26, 2015, 01:25:13 am »
... They come in a variety of speeds, blade configurations, and sizes, with 'power' ranging from 'butterly fart' to 'tornado'.
It's a fan. Go pick one you can source and fit it.
Offline nctnico
Re: Fan for UPS
« Reply #4 on: November 26, 2015, 01:45:20 am »
When replacing a fan always make sure airflow and static pressure are at least similar on the replacement fan. There are huge differences but a higher quality fan can be quieter while providing the same airflow (and pressure).
  • Country: at
Re: Fan for UPS
« Reply #5 on: November 26, 2015, 01:50:28 am »
 :palm: the new fan must have the same flow rate or more.
Other idea someone Print me an Adapter out or help me get some of that: http://www.com-tra.de/shop/de_de/produkt/lID_is_4167_and_Fan-Adapter_40-60mm_transparent_exzentrisch.html
80x80 to 120x120
so which (industrial) Company build high Quality Fans?
And the other Problem are the shipping cost... a ordinar fan cost <20€ and shipping 60€ or so.....  :scared:
Offline rch
  • Country: wales
Re: Fan for UPS
« Reply #6 on: December 05, 2015, 07:03:14 pm »
Noctua fans are reasonably cheap and come in various loudness and flow ratings.  Or any two or three pin PC fan with double ball-bearings will probably be ok if it claims to be quiet and high airflow, because you are already paying a premium for the bearings.  Get it from any PC parts place, should be less then 15 euros including postage from your country or next door one.  Cut the leads 3 cm from the fan and splice on your existing leads (in case they are heat resistant) with heat shrink over the splice.  Just use the relevant two leads if it is a 3 pin fan and insulate the remnant of the yellow one.
Offline mariush
Re: Fan for UPS
« Reply #7 on: December 05, 2015, 07:57:18 pm »
I think CoolerMaster Blade Master 80 may be close to your needs: http://www.coolermaster.com/cooling/case-fan/blade-master-80/
Amazon link : http://www.amazon.com/Cooler-Master-Blade-80-Computer/dp/B0030DSECK  and Newegg link : http://www.newegg.com/Product/Product.aspx?Item=N82E16835103071
but since you're from Austria, you'd probably be better if you find it at some European store , or try amazon.de / amazon.co.uk
  • Country: at
Re: Fan for UPS
« Reply #8 on: December 05, 2015, 08:20:22 pm »
10 USD Fan 50USD shipping to Austria.  :-\
Online DimitriP
Re: Fan for UPS
« Reply #9 on: December 05, 2015, 08:58:47 pm »
How about
http://www.ebmpapst.com/en/contact/locations_worldwide/locations_worldwide_detail_126.php?cId=126
Distributor for compact fans
Compex Ges.m.b.H
Wurlitzergasse 10/3
1160 Wien
Phone: +43 1 4804223
Fax: +43 1 4864230
compex.wien@utanet.at
edit to add search results
after some quick poking around...    http://www.ebmpapst.com/en/products/compact-fans/axial-compact-fans/axial_compact_fans.php
8312N looks lgood ...
more m3/h and  less noise than your existing fan when new
« Last Edit: December 05, 2015, 09:14:50 pm by DimitriP »
  • Country: at
Re: Fan for UPS
« Reply #10 on: December 05, 2015, 09:04:21 pm »
thx
