Hi All
Ive recieved this power supply, I'm trying to repair it but years of being a "board swapper" have spoiled me.
symptom is:
polarity is reversed and max output is only 0.55v (-O/P , +O/P)
fine and course pots operate in the opposite direction (P1 , P2) i.e right to left to get the max 0.55v both pots read good (1K and 5K)
The unit did work momentarily with a 15v output. "percussive" troubleshooting showed no signs of returning any functionality. I've cleaned and tinned the card edge connector as well as a couple of dryish looking joints with no fix. everything I measure appears to be spec or very close.
one resistor screened on the main PCB marked R17 doesn't seem to tally with the circuit diagram, Its a 680k resistor but is marked S.O.T on the diagram?? another R17 appears up with the 2N3055s. this r17 and r16 both read 1ohm as expected.
Overcurrent protection the problem? I'm green on electronics theory as you can probably tell (most i have to do in the day job is continuity)
if anyones got experience with these and any suggestions of likely causes that would be great. also somebody has been in for a repair, replaced power switch so imagine something could have gotten meddled with.
heres a link to the manual/schematic I'm referencing.
https://ia601700.us.archive.org/21/items/FarnellE302StabilisedPowerSupplyUnitManual/FarnellE30-2Psu.pdf
