Author Topic: Farnell EC30/2 - what X/Y rated capacitor from negative to earth?  (Read 969 times)
Offline bd139Topic starter
« on: September 08, 2017, 11:57:58 am »
I've got a Farnell EC30/2 bench supply here. It has a lurking cracked and knackered RIFA X class smoke bomb capacitor in it across the negative and ground terminals. This is GOING as I distrust the infernal things after a few small fires.
This is a floating supply with no isolation or floating voltage limits specified.
Now AFAIK this should be a Y rated capacitor in 2017. Am I ok stuffing a Y1 across it instead?
Offline macboy
Re: Farnell EC30/2 - what X/Y rated capacitor from negative to earth?
« Reply #1 on: September 08, 2017, 12:47:17 pm »
In general, class X are for line to neutral applications, and class Y are for line or neutral to ground applications. So yes, if anything it should be class Y, and since Y1 is "better" than Y2, you should be OK.
« Reply #2 on: September 08, 2017, 01:02:51 pm »
Perfect - thanks for feedback :)
