Hi folks,
I am troubleshooting a faulty Monacor PA-12040 PA Mixing Amplifier.
I already fixed some things:
- Bulging high-pass filter caps (per-channel, C25 1000u in the pic)
- Bad connector/switch contacts (isopropanol cleaning)
However, the output level of channel 3 is too low.
Compared with the other two channels, the inputs of the first stage (U5) are equal but the outputs of the op-amps differ. The output levels and phases are in fact equal to the inputs (using a test-tone, pins 1==2==3 and 7==5==6) as if they were configured in unity gain.
I checked most of the resistors that configure the gain in circuit (R42, R44, R45, R46, R47, R49) but they all seem to be in tolerance.
U6 is putting some gain on the signal.
I am leaning towards a broken op-amp U5 but I am unsure as I have basically zero experience troubleshooting stuff like this.
I am very grateful for any tips 🙂
