Hello guys,
I bought an advertised working fluke 335d, turns out it isn't working. After price renegotiation I decided to keep the unit and see what I can do.
The unit does not go into operate-mode, the current limit indicator is constantly lit.
The Master Reference Testpoint reads 14.9990V constant.
The current limit, trip and vernier are at the correct settings.
I tried following the Power-Up Fault Isolation instructions. The A8A2 Pre-Regulator is not humming loudy and the R8 resistor looks fine, although resistance measurement in circuit shows 82.6Ohm instead of 430Ohm (Would that only be measurable out of the circuit?). Which lead me to Step 7 - Troubleshoot and repair problem pcb board or boards.
I already found a pretty dead cap (C13) on the Chopper Amp board. I cut that one off.
From my limited electronics understanding, but seeing the schematics I would assume that not having this capacitor would already make the device unfunctional?
One other test I did was measuring the voltage drop across the shunt resistor R22 on the Series Pass Driver board.
The range is set to 10V. This should give me 0.01mA according to
https://xdevs.com/doc/Fluke/FLUKE%20335D%20Instruction.pdf 3-11 (p.20/58) but I observed a voltage drop of 0.01V which would be equal to 1mA.
For 100V and 1000V it gave me 12mV=1.2mA and 70mV=7mA when it should've been 0.1mA and 1mA (but I don't know if this is the correct spot to measure).
From what I can tell for now is that when the device is powered up from cold the voltage drop looks like this:
otherwise like this:
Changes at different voltage dials on the front lead to voltage drop spikes ranging from 10-30mV at the shunt. It sounds like a relay engaging at about 22mV.
https://streamable.com/rbbzs9Here cold boot at around 22mV voltage drop the device produces an very audible sound (the same as above?) but longer and higher frequency in comparison to the video above since the voltage is slowly rising (it also does the same sound on the falling side). I would think a very fast switching relay?
https://streamable.com/9zj283The mains power consumptions stays at all times at about 35W. Nothing else changes value during the audibile sound, no extra power consumption, voltage ref stays constant.
Before I order a whole set of new capacitors for the pcb's I would like some input on the matter. Does this ship already appear sunken or is it salvagable?
Are there any quick checks I can do? Is this even testable without the C13 on the chopper amp pcb?
Thank you for reading this convoluted mess!
Datasheet:
https://assets.fluke.com/manuals/335d____imeng0100.pdfKind regards,
Hendrik
